v.in.dxf
David Viebrock
viebrock at gis.cwu.edu
Wed Apr 10 08:00:00 EDT 1996
The problem may be in the GRASS vector map. You may have overlapping
line segments which result in two lines intersecting but with no
connecting nodes. This results in a "dangling" segment. If there are no
obvious dangling lines then run v.digit and make sure all nodes are
snapped. You might also try running v.support before v.out.dxf and
increasing the snapping threshold somewhat. Careful with this one as it
may have unpredictable results (in my experience anyway).
Also, you might want to check out the v.proj command if you're trying to
import it to another LOCATION.
-Dave Viebrock
On Tue, 9 Apr 1996, Scott Grover wrote:
> Dear Grass Users:
> I am using GRASS 4.15 with Linux 1.2.13. I am receiving the dreaded
> "segmentation fault" error when attempting to import a dxf file using
> v.in.dlg. I used v.out.dlg on a GRASS file containing lines, used a 2nd
> program to change the datum (nad1927 to nad1983) and attempted to import the
> new dxf. I can read the same file successfully into another application, so
> I am suspecting my v.in.dxf.
> Has anyone else had a similar experience or could you offer any suggestions
> or work arounds? The overall goal is simply (or not so simply) to update
> the maps' datum from 1927 to 1983.
> Thanks for your response...
> scott grover
> scottg at horne.com
