Aspect map..
William A Perkins
perk at phoebus.pnl.gov
Wed Apr 3 07:00:00 EST 1996
>>>>> "Tarek" == Tarek Sadek <sadek at aqua.civag.unimelb.EDU.AU> writes:
Tarek> Hi Grassers,
Tarek> I am looking for a code which can determine the aspect map
Tarek> from a DEM in degrees azimuth (measured every 1
Tarek> degree). All programs avialble in the current version
Tarek> calculate the aspect of the cells every 45 degrees
Tarek> (i.e. 0,45,90,.....,360 degrees) such as r.watershed,
Tarek> r.slope.aspect,..etc. Also I can't find r.water.aspect
Tarek> which I think it might do the job.
Tarek> tny help would be so appreciated.
Tarek> Cheers,
Tarek> Tarek Sadek
Tarek> Ph.D. Student
Tarek> Department of Civil and Environmental Engineering
Tarek> University of Melbourne
Tarek> Parkville, Vic. 3052
Tarek> Australia
Tarek> Tel: +61 3 9344 7178
Tarek> Fax: +61 3 9344 6215
Tarek> E-mail address: sadek at aqua.civag.unimelb.edu.au
Tarek> URL: http://www.civag.unimelb.edu.au/~sadek
Tarek> ------
Tarek,
I think this would be relatively easy to code yourself. The
documentation for the Arc/Info GRID function SLOPE() presents a method
called the ``average maximum technique'', referring to
Burrough, P.A., 1986. Principles of Geographical Informatioin
Systems for Land Resources Assessment. Oxford University Press,
New York, p. 50.
The method uses a 3x3 neighborhood in the DEM:
a b c
d e f
g h i
Slope is computed as
_______________
| dz 2 dz 2
S = | (--) + (--)
\| dx dy
where
dz (a + 2 d + g) - (c + 2 f + i)
dx 8 cell
x
and
dz (a + 2 b + c) - (g + 2 h + i)
dy 8 cell
x
They also indicate that if any of the neighboring cells are missing
the value of the current cell (e) is assumed for the missing cell.
Given that, I have assumed (and I beleive I'm correct) that aspect
(as an azimuth) would be computed as
dy dz / dx
aspect = atan(--) = atan(-------)
dx dz / dy
with proper adjustments for negative angles.
I have coded something similar in Arc/Info GRID, which uses only 4
neighbors, as in
b
d e f
h
and handles missing values differently. I think either method could
be coded in r.mapcalc without difficulty, but I have not done it.
Hope this helps.
Bill
Bill Perkins
Battelle Pacific Northwest Laboratories
Environmental Technologies Division, Hydrology Group
P.O. Box 999 MSIN K9-36
Richland, Washington, USA 99352
voice: (509) 372-6131 fax: (509) 372-6328 email: wa_perkins at pnl.gov
