Linux CD- r.in.ll
    Massimo Vincini
    radlab1.pc.unicatt.it at aixmiced.mi.unicatt.it
    Wed Apr  3 07:00:00 EST 1996
I am running Linux and XWindows on a PC, and recently installed XGrass4.1
from the CD available from Andreas Holz.
It's running well except of a little bug (may be a XGRASS bug or a bug
od Andreas CD): When I try to convert lat-lon to UTM with r.in.ll
using XGRASS (and not the grass shell which works properly) the
syntax that X gives to the lat-lon corner is wrong : ... corner=sw,lat=xxN....
Whereas the correct command is corner=sw,xxN...
Any suggestion? (not about my english!)
Massimo Vincini
radlab1 at pc.unicatt.it
