need help
Philip Verhagen philip at raap2.ivambv.uva.nl
Tue Apr 2 07:00:00 EST 1996
> From grass-lists-owner at moon.cecer.army.mil Tue Apr  2 13:08 eur 1996
> Date: Tue, 2 Apr 1996 10:05:24 +0200
> From: pubu at gfi.uib.no (Pu Bu Ci Ren)
> To: grassu-list at relay.cecer.army.mil
> Subject: need help
> Mime-Version: 1.0
> Hi, everybody:
> I am new user, I have grass4.1 SGI binary version running in my machine.
> I am working on LANDSAT MSS data, because I don't have tape driver, so I
> can not read data directly from tape using Grass 4.1, what I have done is
> reading data in other place, transfer it  to my hard disk, then I use small
> program which is written by me to extract each band file from the big image
> file on hard disk, the data format is 8 bit binary file, I use XV to display
it
> , it is successful.
> When I use grass, I created a location and mapsheet for mss data, I input the
> column and row number( 3600, 2286), then move all four band files to director
y
> cell under mapsheet MSS, then I try to use d.rast to display it, I got messag
e
> : can't open rast file .... ,
> so can somebody help me ?
> thanks
Before using the maps, run r.support on each of them.
Good luck,
Philip Verhagen
