XGRASS DISPLAY LIB ERROR
    Angus Carr
    apcarr at FLASH.LakeheadU.CA
    Mon Apr  1 07:00:00 EST 1996
Ah, the joys of silly OS's....
Linux is not the problem here.
GRASS expects an 8-bit pseudo-color driver.
Don't use 16-bit color with GRASS.
If you need 16-bit color, I hope you have more success than I did hacking
XDRIVER. Someone has already done this for the Alpha, and it was posted
somewhere that doesn't come to mind right now. I think you can find it
from REGIS, and poke around looking for the Alpha stuff. It's in there.
I played with it, but then had to do some real school work, and had to stop.
Good Luck- post your results!
Angus.
On Sun, 31 Mar 1996, srpage wrote:
> I am running Linux and XWindows on a PC, and recently installed XGrass4.1
> from the CD available from Andreas Holz.   Everything seems to be working
> properly, except for when I attempt to start a graphics monitor, I get the
> following error:
> XGRASS DISPLAY ERROR: Not enough colors available.  Make more available
> before starting again.
> I have XFree86 configured for 16bit color, so I do not beleve this is the
> problem.
> Has anyone seen or heard of this problem?
> Thanks,
> Randy Page
> hansman at erols.com
