Resent mail
    Robert White
    rwhite at gilgal.tamu.edu
    Tue Aug 13 10:10:34 EDT 1996
Sorry about not mailing you sooner. I did get your message. You know how things
are when you get back from vacation. You spend the same amount of time you were
gone to do what was waiting for you when you get back.
I did try the MAX fix you sent and it worked. However, I did come up with
another error on the build for display now. It is complaining of a library
problem.
        cc -o /usr/grass/grass4.1/sgi/bin/xgdisplay -s   OBJ.sgi/args.o
 OBJ.sgi/band.o  OBJ.sgi/barattr.o  OBJ.sgi/barbox.o  OBJ.sgi/barscale.o
 OBJ.sgi/chlist.o  OBJ.sgi/client.o  OBJ.sgi/coloropt.o  OBJ.sgi/crtecolor.o
 OBJ.sgi/drawgrid.o  OBJ.sgi/exit.o  OBJ.sgi/font.o  OBJ.sgi/getcat.o
 OBJ.sgi/getdatafh.o  OBJ.sgi/grammar.o  OBJ.sgi/grid.o  OBJ.sgi/gridbox.o
 OBJ.sgi/gridgadg.o  OBJ.sgi/handler.o  OBJ.sgi/highlight.o  OBJ.sgi/layout.o
 OBJ.sgi/labelbox.o  OBJ.sgi/legend.o  OBJ.sgi/lex.o  OBJ.sgi/linewgadg.o
 OBJ.sgi/menubar.o  OBJ.sgi/menucb.o  OBJ.sgi/main.o  OBJ.sgi/mode.o
 OBJ.sgi/objbutton.o  OBJ.sgi/object.o  OBJ.sgi/popup.o  OBJ.sgi/qrastpl.o
 OBJ.sgi/qrasttext.o  OBJ.sgi/queryraster.o  OBJ.sgi/redrwarea.o
 OBJ.sgi/ruler.o  OBJ.sgi/scroll.o  OBJ.sgi/selpixpl.o  OBJ.sgi/sitegadg.o
 OBJ.sgi/siteicon.o  OBJ.sgi/stdsite.o  OBJ.sgi/stdsitepl.o  OBJ.sgi/toolbox.o
 OBJ.sgi/units.o  OBJ.sgi/upbarbox.o  OBJ.sgi/upgridbox.o  OBJ.sgi/uprastpl.o
 OBJ.sgi/xwd.o /usr/grass/grass4.1/src/libes/LIB.sgi/libvect.a
/usr/grass/grass4.1/src/libes/LIB.sgi/libdig2.a
/usr/grass/grass4.1/src/libes/LIB.sgi/libgis.a
/usr/grass/grass4.1/src/libes/LIB.sgi/libdisplay.a
/usr/grass/grass4.1/src/xgrass/libes/LIB.sgi/libXgd.a
/usr/grass/grass4.1/src/xgrass/libes/LIB.sgi/libXgi.a -L/usr/lib -lXm
-L/usr/lib -lXext -L/usr/lib -lXt  -lX11
/usr/grass/grass4.1/src/xgrass/libes/LIB.sgi/libXpm.a
/usr/grass/grass4.1/src/libes/LIB.sgi/libdisplay.a -ll -lPW -lm
ld: WARNING 84: /usr/grass/grass4.1/src/libes/LIB.sgi/libvect.a is not used for
resolving any symbol.
ld: WARNING 84: /usr/grass/grass4.1/src/libes/LIB.sgi/libdig2.a is not used for
ld: WARNING 84: /usr/grass/grass4.1/src/libes/LIB.sgi/libdisplay.a is not used
for resolving any symbol.
ld: ERROR 33: Unresolved text symbol "XAllocColor" -- 1st referenced by
/usr/grass/grass4.1/src/xgrass/libes/LIB.sgi/libXpm.a(create.o).
ld: INFO 60: Output file removed because of error.
*** Error code 1 (bu21)
GISGEN failure at STEP: src/xgrass/display
I haven't had much time to try to look into it. Did you have the same problem?
Robert
