if the monitor is not properly closed, check the 'locks' directory under the GRASS directory. You should remove the mon.* files that you find there. -- Andrea Giacomelli andreag at idra6.iar.polimi.it http://idra6.iar.polimi.it:8080/~andreag tel: +39-2-23996233 fax: +39-2-23996207
