Undeliverable Message
MAILER-DAEMON at WOOD-VINES.ARMY.MIL
Thu Feb 8 07:00:00 EST 1996
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: <grassu-list at max.cecer.army.mil>
Cc:
Subject: Re: subsetting a vector
Message not delivered to recipients below. Press F1 for help with VNM
error codes.
VNM3043: MR MARK ADAMS at TEC@FLW DCD
VNM3043 -- MAILBOX IS FULL
The message cannot be delivered because the
recipient's mailbox contains the maximum number of
messages, as set by the system administrator. The
recipient must delete some messages before any
other messages can be delivered.
The maximum message limit for a user's mailbox is
10,000. The default message limit is 1000 messages.
Administrators can set message limits using the
Mailbox Settings function available in the
Manage User menu (MUSER).
When a user's mailbox reaches the limit, the
user must delete some of the messages before
the mailbox can accept any more incoming messages.
---------------------- Original Message Follows ----------------------> To se
lect a zone of raster map in grass we just need
> to define the region and then
> r.mapcalc "new.map = old.map"
> Is there any way to do the same with a vector?
> I have a very large vector of coastlines and I'm
> interested only in one particular region.
> Thanks!
> Agus
Try v.cutter
Susan Huse /\ http://www.regis.berkeley.edu/sue
REGIS / \ / \/ \ /\ sue at regis.berkeley.edu
University of California / / \ (510) 643-6307
Berkeley \ / \
