Undeliverable Message
MAILER-DAEMON at WOOD-VINES.ARMY.MIL MAILER-DAEMON at WOOD-VINES.ARMY.MIL
Wed Feb 7 07:00:00 EST 1996
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To:            <grassu-list at max.cecer.army.mil>
Cc:
Subject:       Re: subsetting a vector
Message not delivered to recipients below.  Press F1 for help with VNM
error codes.
        VNM3043:  MR MARK ADAMS at TEC@FLW DCD
VNM3043 -- MAILBOX IS FULL
   The message cannot be delivered because the
   recipient's mailbox contains the maximum number of
   messages, as set by the system administrator.  The
   recipient must delete some messages before any
   other messages can be delivered.
    The maximum message limit for a user's mailbox is
   10,000.  The default message limit is 1000 messages.
   Administrators can set message limits using the
   Mailbox  Settings function available in the
   Manage User menu  (MUSER).
   When a user's mailbox reaches the limit, the
   user must delete some of the messages before
   the mailbox can accept any more incoming messages.
----------------------  Original Message Follows  ----------------------Hi Agus
  You can use the v.cutter command to cut out a region. You'll need to label
the cutter and support it. Rick
On Wed, 7 Feb 1996, Agustin Lobo wrote:
> To select a zone of raster map in grass we just need
> to define the region and then
> r.mapcalc "new.map = old.map"
> Is there any way to do the same with a vector?
> I have a very large vector of coastlines and I'm
> interested only in one particular region.
Rick Thompson-   Research Specialist          E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Hall Rm. 12                             Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
DISCLAIMER: Any opinions or comments about any product, organization,
            or individual expressed in the above text are my own.
