r.in.ascii dying with segmentation fault <sigh>
Olga Waupotitsch
olga at diego.cecer.army.mil
Sun Feb 4 07:00:00 EST 1996
In info.grass.user you write:
>Hi All,
>To the point: My first attempt at using floating point r.in.ascii allowed
>the parameter input but then died immediately on trying to import the file.
>It used to work fine (and I used a file that I've imported before).
>History that may be relevant:
>After a blind struggle I managed to get most of the floating point update
>compiled on our SGI Indy (R4400) running Irix 5.3. One modification that
>was instrumental was to add DATETIMELIB = /usr/lib/libc.so.1 to the
>src/CMD/generic/make.mid file. Otherwise, I used the SGI header file that
>was posted to the list some time ago, which I've included below.
Bill Brown and Helena are running fp GRASS on SGI.
I am sorry for the problems you are having, it is very hard
to include all the new things in one .tar file.
I want to debug this segmentation fault you got using r.in.ascii.
Can you please send me the input file?
Thanx!
Olga
