Floating pnt upgrade on SGI - recompile trouble
Olga Waupotitsch
olga at diego.cecer.army.mil
Sun Feb 4 07:00:00 EST 1996
In info.grass.user you write:
>Hi, I'm trying to compile the floating point upgrade on our SGI Indigo2
>(R4400 chipset). When I ran GISGEN it got as far as front.end and died.
>Olga kindly provided part of the solution--that the gis library was not
>recompiling. I removed all the .o files in src/libes/gis and recompiled with
>gmake4.1. Resuming GISGEN got me as far as d.display. I then recompiled
>everything in the src/libes/* directories but GISGEN still falls down at
>d.points, unable to resolve 'region'.
>Can anybody suggest what to do next?
>Cheers, and thanks,
>Peter Briggs
>CSIRO Centre for Environmental Mechanics
>GPO Box 821, Canberra, ACT 2601, Australia
>ph: +61 6 246 5554 fax: +61 6 246 5560
>email: pbriggs at enmech.csiro.au
>http://www.enmech.csiro.au/pyelab/people/pbcv.htm
Hi!
Maybe you just don't have the correct libes/gis/sites.c file
(I noticed it was missing from the tar file)
Please substitute your libes/gis/sites.c with the included file.
Sorry for the delayed reply!
Olga
#pragma ident "$Id: sites.c,v 1.39 1995/08/17 21:03:29 mccauley Exp mccauley
* These functions and definitions support the site format for 4.2
* (format proposed by Dave Gerdes):
* easting|northing|[z|[d4|]...][#category_int] [ [@attr_text OR %flt] ... ]
* to allow multidimensions (everything preceding the last '|') and any
* number of text or numeric attribute fields.
* Author: James Darrell McCauley <mccauley at ecn.purdue.edu>
* 31 Jan 1994
* $Log: sites.c,v $
* Revision 1.39 1995/08/17 21:03:29 mccauley
* fixed bug related to time to stime conversion
* Revision 1.38 1995/07/25 15:14:45 mccauley
* fixed error for cat in G_site_describe
* Revision 1.37 1995/07/17 20:55:48 mccauley
* change G_strchr to G_strstr
* Revision 1.36 1995/07/17 11:14:43 mccauley
* took out has_cat and made part of struct
* support for floating point categories
* Revision 1.35 1995/07/14 14:04:14 mccauley
* renamed G_site_get_fmt to G_site_describe
* Revision 1.34 1995/07/14 11:39:49 mccauley
* changed G_site_destroy_struct to G_site_free_struct
* Revision 1.33 1995/07/13 19:58:28 mccauley
* added G_site_destroy_struct
* Revision 1.32 1995/07/05 12:55:40 mccauley
* added warning flags for old API usage
* Revision 1.31 1995/07/05 12:25:48 mccauley
* modified G_site_put to use (Site *) instead of (Site)
* Revision 1.30 1995/07/05 12:07:17 mccauley
* removed extra spaces in G_site_puts output
* Revision 1.29 1995/07/05 12:02:48 mccauley
* added G_site_puts (analog to sprintf for G_site_put)
* Revision 1.28 1995/07/05 12:01:20 mccauley
* fixed bug in G_sites_get_fmt
* Revision 1.27 1995/06/29 16:27:00 mccauley
* fixed malloc error in G_site_new_struct.
* Revision 1.26 1995/06/29 12:08:25 mccauley
* added G_site_in_region.
* Revision 1.25 1995/06/20 16:08:24 mccauley
* first version put in 4.2 release
* Revision 1.24 1995/05/24 00:36:27 mccauley
* added old functions for bc while porting
* Revision 1.23 1995/05/24 00:05:31 mccauley
* added DateTime stuff
* Revision 1.22 1995/04/17 22:56:59 mccauley
* added G_site_put_hdr/G_site_get_hdr. Header records include
* "name|", "desc|", "labels|", and "time|".
* Revision 1.21 1995/02/22 03:23:19 mccauley
* more ctype-like changes.
* Revision 1.20 1995/02/22 03:14:23 mccauley
* changed conditionals to use ctype-like defines (e.g., ispipe).
* Revision 1.19 1995/02/22 02:53:48 mccauley
* skip over header lines in G_site_get and G_site_get_fmt.
* Revision 1.18 1995/02/22 02:45:54 mccauley
* added sites functions from 4.1 that we'll keep.
* Revision 1.17 1995/02/22 02:25:03 mccauley
* changed names of functions to G_site_xxx().
* Revision 1.16 1995/02/21 07:53:48 mccauley
* changed "static char sites_api_rcsid" to pragma ident.
* added function declarations for those int functions that
* should be defined in gis.h. fixed pointer-int comparison
* in next_att().
* No warnings (from this code) for "gcc -Wall."
* Revision 1.15 1995/02/21 07:27:32 mccauley
* added qsort comparison functions.
* still need to re-write G_guess_site_fmt to reflect changes in
* G_new_get_site.
* Revision 1.14 1995/02/21 07:21:49 mccauley
* replaced repititive code with next_att()
* removed erroneous comments. ran indent.
* Revision 1.13 1995/02/21 02:33:14 mccauley
* changes to ignore superflous spaces not contained within quotes.
* changes to use ctyle functions and to do selective reads.
* Revision 1.12 1995/02/18 22:34:37 mccauley
* a few changes to read selective fields (according to what
* was allocated for).
* Revision 1.11 1995/02/09 02:49:20 mccauley
* Added check for dim_alloc in G_new_get_site.
* Removed erroneous check in G_new_put_site.
* Still have error in selective reads.
* Revision 1.10 1995/02/09 00:07:03 mccauley
* Debugged G_guess_site_fmt and ran indent.
* Still need to rewrite G_guess_site_fmt and G_new_get_site so
* that we don't have multiple exits points (too many 'return 0's).
* Revision 1.9 1995/02/08 23:12:20 mccauley
* Added first version of G_guess_site_fmt (untested).
* Revision 1.8 1995/02/08 01:26:27 mccauley
* Changed return vals of G_new_get_site for easier diagnostics.
* For category and decimal attributes, on possible reason for a
* non zero return value is the value does not immediately follow
* the attribute tag (# or %). E.g., "# 2" or "% 23.4" will cause
* an error. Remember to put this in programmers' docs!
* Revision 1.7 1995/02/08 00:54:49 mccauley
* Added a few more checks. Fixed a bug in cleanse_string.
* Revision 1.6 1995/02/08 00:06:24 mccauley
* Added a few checks, combined a few, and changed do/while to while after #.
* Revision 1.5 1995/02/07 23:33:07 mccauley
* fixed bug with G_new_put_site [.dim_alloc already decremented by 2]
* Revision 1.4 1995/02/07 23:24:06 mccauley
* added comments and ran 'indent'
* Revision 1.3 1995/02/07 23:16:04 mccauley
* if length of string attribute is zero, it is not printed. if there
* are no non-zero string attributes, no string attributes are printed.
* Revision 1.2 1995/02/07 21:15:13 mccauley
* recompiled with 'gcc -Wall' and got rid of "unused var" warnings.
* added return values to some functions.
* Revision 1.1 1995/02/07 21:01:12 mccauley Initial revision
#include "gis.h"
#include <ctype.h>
#include <string.h>
#define DQUOTE '"'
#define SPACE ' '
#define BSLASH 92
#define PIPE '|'
#define ispipe(c) (c==PIPE)
#define isnull(c) (c==(char)NULL)
#define isquote(c) (c==DQUOTE)
void G_site_free_struct (s)
Site *s;
/* Free memory for a Site struct */
if(s->dim_alloc)
free(s->dim);
if(s->str_alloc)
free(s->str_att);
if(s->dbl_alloc)
free(s->dbl_att);
free(s);
Site *G_site_new_struct (cattype, n_dim, n_s_att, n_d_att)
RASTER_MAP_TYPE cattype;
int n_dim, n_s_att, n_d_att;
/* Allocate memory for a Site struct. Returns a properly allocated
site struct or NULL on error.
cattype= -1 (no cat), CELL_TYPE, FCELL_TYPE, or DCELL_TYPE
int i;
Site *s;
if (n_dim < 2 || n_s_att < 0 || n_d_att < 0)
fprintf (stderr, "PROGRAMMER ERROR: invalid # dims or fields in %s\n",
"G_site_new_struct");
exit (-1);
if ((s = (Site *) G_malloc (sizeof (Site))) == NULL)
return (Site *) NULL;
s->cattype=cattype;
s->ccat=s->fcat=s->dcat=0;
if (n_dim > 2)
if ((s->dim =
(double *) G_malloc ((n_dim - 2) * sizeof (double))) == NULL)
s->dim_alloc = n_dim - 2;
if (n_d_att > 0)
if ((s->dbl_att =
(double *) G_malloc (n_d_att * sizeof (double))) == NULL)
s->dbl_alloc = n_d_att;
if (n_s_att > 0)
if ((s->str_att =
(char **) G_malloc (n_s_att * sizeof (char *))) == NULL)
else
for (i = 0; i < n_s_att; ++i)
if ((s->str_att[i] =
(char *) G_malloc (MAX_SITE_STRING * sizeof (char))) == NULL)
s->str_alloc = n_s_att;
return s;
int G_site_get (ptr, s)
FILE *ptr;
Site *s;
* Reads ptr and returns 0 on success,
* -1 on EOF,
int cleanse_string ();
char sbuf[MAX_SITE_LEN], *buf;
char ebuf[128], nbuf[128];
char *next_att ();
int G_projection(), G_scan_northing(), G_scan_easting();
int n = 0, d = 0, c = 0, dim = 0, err;
buf = sbuf;
if ((buf = fgets (sbuf, 1024, ptr)) == (char *) NULL)
return EOF;
while (*buf == '#' || !isdigit(*buf) )
return EOF;
while ((*buf == '#' || !isdigit(*buf)) && *buf != '-' && *buf != '+')
return EOF;
if (buf[strlen (buf) - 1] == '\n')
buf[strlen (buf) - 1] = (char) NULL;
if ((err = sscanf (buf, "%[^|]|%[^|]|%*[^\n]", ebuf, nbuf)) < 2)
fprintf (stderr, "ERROR: ebuf %s nbuf %s\n", ebuf, nbuf);
return -2;
if (!G_scan_northing (nbuf, &(s->north), G_projection ()) ||
!G_scan_easting (ebuf, &(s->east), G_projection ()))
return -2;
/* move pointer past easting and northing fields */
while (!ispipe(*buf) && !isnull(*buf))
buf++;
if ( !isnull(*buf) && !isnull(*(buf + 1)))
buf++;
else
return -2;
buf++;
buf++;
else
return 0;
/* check for remaining dimensional fields */
while (G_index (buf, PIPE) != (char) NULL)
if (dim < s->dim_alloc)
if ((err = sscanf (buf, "%lf|", &(s->dim[dim++]))) < 1)
return -2;
else
buf++;
if (isnull(*buf))
return 0;
if (!isnull(*(buf + 1)))
buf++;
else
return -2;
/* no more dimensions-now we parse attribute fields */
while (!isnull(*buf))
switch (*buf)
case '#': /* category field */
if (n == 0)
switch(s->cattype)
case CELL_TYPE:
if(sscanf (buf, "#%d", &s->ccat)==1)
n++;
break;
case FCELL_TYPE:
if(sscanf (buf, "#%f", &s->fcat)==1)
n++;
break;
case DCELL_TYPE:
if(sscanf (buf, "#%lf", &s->dcat)==1)
n++;
break;
else
sscanf (buf, "#%d", &err);
/* move to beginning of next attribute */
if ((buf = next_att (buf)) == (char *) NULL)
return 0;
break;
case '%': /* decimal attribute */
* if (d >= s->dbl_alloc) return -4;
if (d < s->dbl_alloc)
if ((err = sscanf (buf, "%%%lf", &(s->dbl_att[d++]))) < 1)
return -4;
return 0;
break;
case '@': /* string attribute */
if (isnull(*buf) || isnull(*(buf + 1)))
return 0;
else
buf++;
default: /* defaults to string attribute */
/* allow both prefixed and unprefixed strings */
if (c < s->str_alloc)
if ((err = cleanse_string (buf)) > 0)
G_strncpy (s->str_att[c++], buf, err);
buf += err;
else
return err;
return 0;
break;
return 0;
int G_site_put (fptr, s)
FILE *fptr;
Site *s;
/* Writes a site to file open on fptr. */
char ebuf[MAX_SITE_STRING], nbuf[MAX_SITE_STRING];
char xbuf[MAX_SITE_STRING], buf[MAX_SITE_LEN];
static int format_double ();
int fmt, i, j, k;
int G_format_northing(), G_format_easting(), G_projection();
fmt = G_projection ();
G_format_northing (s->north, nbuf, fmt);
G_format_easting (s->east, ebuf, fmt);
sprintf (buf, "%s|%s|", ebuf, nbuf);
for (i = 0; i < s->dim_alloc; ++i)
format_double (s->dim[i], nbuf);
sprintf (xbuf, "%s|", nbuf);
G_strcat (buf, xbuf);
switch(s->cattype)
case CELL_TYPE:
sprintf (xbuf, "#%d ", s->ccat);
break;
case FCELL_TYPE:
sprintf (xbuf, "#%g ", s->fcat);
break;
case DCELL_TYPE:
sprintf (xbuf, "#%g ", s->dcat);
break;
for (i = 0; i < s->dbl_alloc; ++i)
format_double (s->dbl_att[i], nbuf);
sprintf (xbuf, "%%%s ", nbuf);
for (i = 0; i < s->str_alloc; ++i)
if (strlen (s->str_att[i]) != 0)
/* escape double quotes */
j = k = 0;
if (G_index (s->str_att[i], DQUOTE) != (char *) NULL)
while (!isnull(s->str_att[i][j]))
if (isquote(s->str_att[i][j]))
xbuf[k++] = BSLASH;
xbuf[k++] = DQUOTE;
else
xbuf[k++] = s->str_att[i][j];
j++;
xbuf[k] = (char) NULL;
else
G_strcpy (xbuf, s->str_att[i]);
G_strcpy (s->str_att[i], xbuf);
if (G_index (s->str_att[i], SPACE) != (char *) NULL)
sprintf (xbuf, "@\"%s\" ", s->str_att[i]);
else
sprintf (xbuf, "@%s ", s->str_att[i]);
fprintf (fptr, "%s\n", buf);
return 0;
int G_site_describe (ptr, dims, cat, strs, dbls)
FILE *ptr;
int *dims, *cat, *strs, *dbls;
* Tries to guess the format of a sites list (the dimensionality,
* the presence/type of a category, and the number of string and decimal
* attributes) by reading the first record in the file.
* -1 on EOF,
* -2 for other error.
int err;
int itmp;
float ftmp;
if (ftell (ptr) != 0L)
fprintf (stderr, "\nPROGRAMMER ERROR: G_site_get_fmt() must be called\n");
fprintf (stderr, " immediately after G_fopen_sites_old()\n");
return -2;
*dims = *strs = *dbls = 0;
*cat = -1;
buf = sbuf;
rewind (ptr);
return EOF;
/* skip over comment & header lines */
rewind (ptr);
return EOF;
rewind (ptr);
return -2;
*dims = 2;
buf++;
if (!isnull(*buf) && !isnull(*(buf + 1)))
buf++;
else
rewind (ptr);
return -2;
buf++;
buf++;
else
rewind (ptr);
return 0;
(*dims)++;
buf++;
if (isnull(*buf))
rewind (ptr);
return 0;
buf++;
else
rewind (ptr);
return -2;
switch (*buf)
sscanf(buf,"#%s ",ebuf);
if(G_strstr(ebuf,".")==NULL && sscanf(ebuf,"%d", &itmp) ==1)
*cat=CELL_TYPE;
else if(G_strstr(ebuf,".")!=NULL && sscanf(ebuf,"%f", &ftmp) ==1)
*cat=FCELL_TYPE;
else
*cat=-1;
while (!isspace (*buf) && !isnull(*buf))
buf++;
rewind (ptr);
return 0;
else
buf++;
break;
(*dbls)++;
buf++;
rewind (ptr);
return 0;
else
buf++;
break;
rewind (ptr);
return 0;
else
buf++;
(*strs)++;
buf += err;
buf++;
rewind (ptr);
return 0;
else
buf++;
break;
rewind (ptr);
return 0;
int G_site_put_head (ptr, head)
FILE *ptr;
Site_head *head;
* Writes site_head struct.
static char buf[128];
if (head->name!=NULL)
fprintf(ptr,"name|%s\n",head->name);
if (head->desc!=NULL)
fprintf(ptr,"desc|%s\n",head->desc);
if (head->form!=NULL)
fprintf(ptr,"form|%s\n",head->form);
if (head->labels!=NULL)
fprintf(ptr,"labels|%s\n",head->labels);
/* time could be in (char *) stime, (DateTime *) time, both, or neither */
if (head->stime!=NULL || head->time !=NULL)
if (head->time != NULL) /* DateTime struct has precendence */
datetime_format (head->time, buf);
fprintf(ptr,"time|%s\n",buf);
else if (head->stime != NULL) /* next check string */
if (head->time==NULL)
if ((head->time=(DateTime *) G_malloc(sizeof(DateTime)))==NULL)
G_fatal_error("Memory error in writing timestamp");
else if (datetime_scan (head->time, head->stime) < 0)
G_warning("Illegal DateTime string");
datetime_format (head->time, head->stime);
fprintf(ptr,"time|%s\n",head->stime);
return 0;
int G_site_get_head (ptr, head)
FILE *ptr;
Site_head *head;
* Fills in site_head struct.
int len;
fprintf (stderr, "\nPROGRAMMER ERROR: G_site_get_head() must be called\n");
return -2;
head->name=NULL;
head->desc=NULL;
head->form=NULL;
head->labels=NULL;
head->stime=NULL;
head->time=NULL;
buf = sbuf;
rewind (ptr);
return EOF;
/* assume header lines are always first records. allow for comments */
len=strlen(buf);
if (buf[len-1]=='\n')
buf[len-1]=NULL;
if (!strncmp(buf,"name|",5))
buf+=5;
head->name=G_strdup(buf);
else if (!strncmp(buf,"desc|",5))
buf+=5;
head->desc=G_strdup(buf);
else if (!strncmp(buf,"form|",5))
buf+=5;
head->form=G_strdup(buf);
else if (!strncmp(buf,"labels|",7))
buf+=7;
head->labels=G_strdup(buf);
else if (!strncmp(buf,"time|",5))
buf+=5;
head->stime=G_strdup(buf);
G_fatal_error("Memory error in allocating timestamp");
if (datetime_scan (head->time , head->stime)<0)
G_warning(datetime_error_msg());
head->time=NULL;
head->stime=NULL;
/* else is it a comment or some invalid header (not a decimal digit) */
rewind (ptr);
return EOF;
rewind (ptr);
return 0;
int G_site_in_region (site, region)
Site *site;
struct Cell_head *region;
/* returns 1 if site is contained within region, 0 otherwise */
/* northwest corner is in region, southeast corner is not. */
double e_ing;
double G_adjust_easting();
e_ing = G_adjust_easting (site->east, region);
if (e_ing >= region->west &&
e_ing < region->east &&
site->north <= region->north &&
site->north > region->south)
return 1;
else
return 0;
static int format_double (value, buf)
double value;
char *buf;
int G_trim_decimal ();
sprintf (buf, "%.8f", value);
G_trim_decimal (buf);
return 0;
int cleanse_string (buf)
char *buf;
char *stop, *p;
p = buf;
* get rid of any SPACEs at beginning while ( !isspace(*buf) && *buf !=
* (char) NULL) buf++; if (*buf == (char) NULL) return -1;
/* find where this string terminates */
if (G_index (buf, DQUOTE) == (char) NULL) /* if no DQUOTEs, */
stop = G_index (buf, SPACE);/* then SPACE separates */
if (stop == (char *) NULL)
return strlen (buf);
else
return (int) (stop - buf);
else /* otherwise string is in DQUOTEs */
{ /* but we must skip over escaped */
/* (BSLASHed) DQUOTEs */
if (*p == DQUOTE)
while (*p != (char) NULL) /* get rid of first DQUOTE */
*p = *(p + 1);
p++;
p = buf;
stop = G_index (p + 1, DQUOTE);
while (*(stop - 1) == BSLASH)
stop = G_index (++stop, DQUOTE);
/* remove backslashes between buf and stop */
while ((p = G_index (buf, BSLASH)) != (char *) NULL && p <= stop)
if (*(p + 1) != (char) NULL && *(p + 1) == DQUOTE)
*p = *(p + 1);
p++;
stop--;
char *next_att (buf)
char *buf;
buf++;
return 0;
else
while (isspace (*(buf + 1)) && !isnull(*(buf + 1)))
buf++;
buf++;
return buf;
int G_site_c_cmp (a, b)
void *a, *b;
/* qsort() comparison function for sorting an array of
site structures by category. */
int result = 0; /* integer to be returned */
double diff;
switch((*(Site **)a)->cattype)
case CELL_TYPE:
diff = (double) (*(Site **) a)->ccat - (*(Site **) b)->ccat;
break;
case FCELL_TYPE:
diff = (double) (*(Site **) a)->fcat - (*(Site **) b)->fcat;
break;
case DCELL_TYPE:
diff = (double) (*(Site **) a)->dcat - (*(Site **) b)->dcat;
break;
if (diff < 0.0 )
result = -1;
else if (diff > 0.0)
result = 1;
return result;
int G_site_d_cmp (a, b)
void *a, *b;
site structures by first decimal attribute. */
double diff;
diff = (*(Site **) a)->dbl_att[0] - (*(Site **) b)->dbl_att[0];
if (diff < 0.0 )
result = -1;
result = 1;
return result;
int G_site_s_cmp (a, b)
void *a, *b;
return strcmp((*(char **)((*(Site **) a)->str_att)),
(*(char **)((*(Site **) b)->str_att)));
* char *
* G_ask_sites_new(prompt, name))
* asks user to input name of a new site list file
* char *
* G_ask_sites_old(prompt, name)
* asks user to input name of an existing site list file
* char *
* G_ask_sites_any(prompt, name)
* asks user to input any site list name
* char *
* G_ask_sites_in_mapset(prompt, name)
* asks user to input name of an existing site list file in
* current mapset
* parms:
* char *prompt optional prompt for user
* char *name buffer to hold name of map found
* returns:
* char *pointer to a string with name of mapset
* where file was found, or NULL if not found
* note:
* rejects all names that begin with .
* FILE *
* G_sites_open_old (name, mapset)
* opens the existing site list file 'name' in the 'mapset'
* FILE *
* G_sites_open_new (name)
* opens a new site list file 'name' in the current mapset
* parms
* char *name map file name
* char *mapset mapset containing map "name"
char * G_find_sites (name, mapset)
char *name, *mapset;
return G_find_file ("site_lists", name, mapset);
char * G_find_sites2 (name, mapset)
return G_find_file2 ("site_lists", name, mapset);
char * G_ask_sites_new (prompt, name)
char *prompt, *name;
char *G_ask_new ();
return G_ask_new (prompt, name, "site_lists", "site list");
char * G_ask_sites_old (prompt, name)
char *G_ask_old ();
return G_ask_old (prompt, name, "site_lists", "site list");
char * G_ask_sites_any (prompt, name)
char *G_ask_any ();
return G_ask_any (prompt, name, "site_lists", "site list", 1);
char * G_ask_sites_in_mapset (prompt, name)
char *G_ask_in_mapset ();
return G_ask_in_mapset (prompt, name, "site_lists", "site list");
FILE * G_sites_open_old (name, mapset)
return G_fopen_old ("site_lists", name, mapset);
FILE * G_sites_open_new (name)
char *name;
return G_fopen_new ("site_lists", name);
/* The following functions are obsolete. */
/* They are retained here only for backwards */
/* compatability while porting applications */
FILE *
G_fopen_sites_old (name, mapset)
char *name;
char *mapset;
FILE *
G_fopen_sites_new (name)
char *name;
G_get_site (fd, east, north, desc)
FILE *fd;
double *east, *north;
char **desc;
char buf[400];
char temp[400];
static char *desc_ptr = NULL;
fprintf(stderr,"WARNING: %s needs modified for the new Sites API\n",
G_program_name() );
if (desc_ptr != NULL)
free (desc_ptr);
desc_ptr = NULL;
*temp = 0;
while (fgets (buf, sizeof buf, fd))
if (sscanf (buf, "point|%[^|]|%[^|]|%[^\n]", ebuf, nbuf, temp) >= 2
|| sscanf (buf, "%[^|]|%[^|]|%[^\n]", ebuf, nbuf, temp) >= 2)
if (G_scan_northing (nbuf, north, G_projection())
&& G_scan_easting (ebuf, east, G_projection()))
G_strip (temp);
*desc = desc_ptr = G_store (temp);
return 1;
return -1;
G_put_site (fd, east, north, desc)
FILE *fd;
double east, north;
char *desc;
int fmt;
G_program_name() );
/* fmt = G_projection(); */
fmt = -1;
G_format_northing (north, nbuf, fmt);
G_format_easting (east, ebuf, fmt);
fprintf (fd, "%s|%s|%s\n", ebuf, nbuf, desc?desc:"");
char * G_site_format (s, fs, id)
Site *s;
char *fs;
int id;
/* sprintf analog to G_site_put with the addition of a field seperator fs
and option of printing site attribute identifiers
char xbuf[MAX_SITE_STRING];
char *nfs, *buf;
int fmt, i, j, k;
buf=(char *)G_malloc(MAX_SITE_LEN*sizeof(char));
nfs = (char *) ((fs == (char *) NULL) ? "|" : fs);
sprintf (buf, "%s%s%s", ebuf, nfs, nbuf);
sprintf (xbuf, "%s%s", nfs, nbuf);
nfs= (fs == NULL) ? " " : fs;
switch(s->cattype)
case CELL_TYPE:
sprintf (xbuf, "%s%s%d ", nfs, ((id==0) ? "" : "#"), (int)s->ccat);
break;
case FCELL_TYPE:
case DCELL_TYPE:
sprintf (xbuf, "%s%s%g ", nfs, ((id==0) ? "" : "#"), (float)s->fcat);
break;
sprintf (xbuf, "%s%s%s", nfs, ((id==0) ? "" : "%"), nbuf);
j = k = 0;
xbuf[k++] = BSLASH;
xbuf[k++] = DQUOTE;
else
j++;
else
sprintf (xbuf, "%s%s\"%s\"", nfs, ((id==0) ? "" : "@"), s->str_att[i]);
else
sprintf (xbuf, "%s%s%s", nfs, ((id==0) ? "" : "@"), s->str_att[i]);
return buf;
