X driver
Cosyn Bart
Bart.Cosyn at rug.ac.be
Tue Jan 30 07:00:00 EST 1996
Hi Paul,
On Mon, 29 Jan 1996, Paul Koch wrote:
> I'm just getting started with GRASS, running it on an HP. It was
> installed by a techie who has since left. I am following the Leicester
> tutorial online. In response to
> GRASS-GRID > d.mon start=x0
> The /driver subdirectory is empty and I'd like to avoid downloading all
> the source files to find a solution. What's the best way to get past
> this error?
check in your subdirectory $GISBASE/src/CMD/lists if you have copied the
file local.example to local and uncomment the following line
src/display/devices/XDRIVER
if you want to run xgrass uncomment also the xgrass stuff.
Here you can also add other sources that you want to compile at the same
time. I hope this will help you out!
Bart
| ir. Bart Cosyn |
| VLIR-project Tunisia |
| Laboratory for Hydrology and Water Management |
| University of Gent |
| Coupure 653, B-9000 Gent |
| Belgium |
| Tel: +/32/9/2646137 |
| Fax: +/32/9/2646236 |
| E-mail: bcosyn at allserv.rug.ac.be |
| URL: http://taoren.rug.ac.be/ |
