contouring in GRASS
Andrew W Ellis
ellis at UDel.Edu
Tue Jan 30 07:00:00 EST 1996
Hello,
I am using r.contour to create a vector contour map from a raster image
and can not seem to figure out how to label the contour lines. The
vector map of the contour lines looks great but is not much use with
labels. Is there an easy way to get labels on the contours without
determining the coordinates of each line on which I want to place a label
and using d.labels or labelling procedures in ps.map?
Additionally, does anyone know if it is possible to move a raster image
to a new location with a different projection and have the image
converted into the new projection (i.e. something like v.proj)?
Much thanks in advance,
Drew
Andrew W. Ellis (302) 831-2344
211 Pearson Hall ellis at strauss.udel.edu
Department of Geography
University of Delaware
Newark, DE 19716
