r.in.ascii dying with segmentation fault <sigh>
Peter Briggs
pbriggs at enmech.csiro.au
Tue Jan 30 07:00:00 EST 1996
Hi All,
To the point: My first attempt at using floating point r.in.ascii allowed
the parameter input but then died immediately on trying to import the file.
It used to work fine (and I used a file that I've imported before).
History that may be relevant:
After a blind struggle I managed to get most of the floating point update
compiled on our SGI Indy (R4400) running Irix 5.3. One modification that
was instrumental was to add DATETIMELIB = /usr/lib/libc.so.1 to the
src/CMD/generic/make.mid file. Otherwise, I used the SGI header file that
was posted to the list some time ago, which I've included below.
If others have a log describing their successful implementation on this
machine I'd sure like to hear it. If I ever get this working I'll happily
post mine.
Cheers, Peter Briggs
CC = cc
ARCH = sgi
GISBASE = /usr/local/grass4.1
UNIX_BIN = /usr/local/bin
DEFAULT_DATABASE = /usr/local/grass4.1/data
DEFAULT_LOCATION = world
COMPILE_FLAGS = -O -cckr
LDFLAGS = -s
XCFLAGS = -D_NO_PROTO -DXM_1_1_BC -Umips
XLDFLAGS = -lPW
XINCPATH =
XMINCPATH =
XLIBPATH =
XTLIBPATH = -L/usr/lib
XMLIBPATH = -L/usr/lib
XLIB = -lX11
XTLIB = -lXt
XMLIB = -lXm
XEXTRALIBS = -lPW
TERMLIB = -ltermlib
CURSES = -lcurses $(TERMLIB)
MATHLIB = -lm
# LIBRULE = ar ruv $@ $?
# LIBRULE = ar ruv $@ $?; ranlib $@
# LIBRULE = ar ruv $@ $?; ar ts $@
# LIBRULE = ar rc $@ `lorder $(OBJ) | tsort`
USE_TERMIO = -DUSE_TERMIO
USE_MTIO = -DUSE_MTIO
USE_FTIME =
DIGITFLAGS = -DUSE_SETREUID -DUSE_SETEUID -DUSE_SETPRIORITY
VECTLIBFLAGS =
GETHOSTNAME = -DGETHOSTNAME_OK
XDRLIB = -lsun
