ascii.to.vect.to.rast
Malcolm Williamson
malcolm at cast.uark.edu
Mon Jan 8 07:00:00 EST 1996
Hi, Norm
Vector features have to be labeled, as lines, areas, or points, in order
to be converted to raster. Normally this is done in v.digit, but it is
also possible to create scripts that would build the needed dig_att file
for you. You will need to run v.support after attributing the features.
-Malcolm Williamson
On Mon, 8 Jan 1996, Norm Bingham wrote:
> we can create a vect file from an ascii file which can
> be displayed, but every time we run v.to.rast it
> says we need to run v.support on the vect file.
> we do that and the rast file is created but all categories
> are the same so the raster image cannot be displayed.
> how do we set the categories so that the rasterized
> image is displayed.
> thanks
> jhp at awips1.abrfc.noaa.gov
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
