different groups
Malcolm Williamson
malcolm at cast.uark.edu
Thu Mar 21 07:00:00 EST 1996
Hi, Stephan
_Read_ permission in GRASS mapsets is controlled entirely by UNIX file
and directory permissions. By making file permissions 644 and directory
permissions 755, any user should be able to use g.mapset to add and read
a mapset. _Write_ permission to mapsets are restricted to the active
mapset chosen when you start up GRASS, which has to be _owned_ by you.
Hope this helps.
-Malcolm Williamson
On Thu, 21 Mar 1996 sw at kreutler.de wrote:
> Hi GRASSlers!
> I have a question about using GRASS with different user groups.
> I'm thinking that only users which are belonging to the group which
> had installed the maps to the file system may use them.
> Is this right?
> Is there a possibility to share the maps with users from other groups?
> thanx in advance,
> Stephan
