postscript printing problem
    Wang Zhong Min
    zhwang at 134.184.15.1.belgium.eu.net
    Thu Mar 21 07:00:00 EST 1996
On 18 Mar 1996 kang at risca.rs.msu.edu wrote:
> > I am using grass4.1.5 on linux (slack 3.0, k1.2.13).
> > i am trying to generate some post script plots, but
> > get a segmentation fault when I try to run ps.map. I
> > have the ps drivers configured and selected correctly. I am
> > also getting a floating point excpetion error on a machine running
> > grass4.1.3 (slack 2.3, k1.2.8). It has no coprocessor,
> > but has floating point emulation enabled in the kernel...
> Did you get the segmentation fault error every time?  Has anyone had the same
> error with the Linux GRASS 4.15 binaries that available on moon?
I had the same problem with GRASS 4.15 binaries from moon.
I run the Kernel 1.3.70 (elf).
Wang Zhong Min
Laboratory of Hydrology
Free University Brussels
Pleinlaan 2, 1050 Brussels
Belgium
zhwang at vub.ac.be
