postscript printing problem
kang at risca.rs.msu.edu kang at risca.rs.msu.edu
Mon Mar 18 07:00:00 EST 1996
> I am using grass4.1.5 on linux (slack 3.0, k1.2.13).
> i am trying to generate some post script plots, but
> get a segmentation fault when I try to run ps.map. I
> have the ps drivers configured and selected correctly. I am
> also getting a floating point excpetion error on a machine running
> grass4.1.3 (slack 2.3, k1.2.8). It has no coprocessor,
> but has floating point emulation enabled in the kernel...
Did you get the segmentation fault error every time?  Has anyone had the same
error with the Linux GRASS 4.15 binaries that available on moon?
Kang,
