open area lines in closed polygons.
    Grass package
    grass at sun1.bham.ac.uk
    Wed Mar 13 07:00:00 EST 1996
?pm at bnr.ca>
content-type: text/plain; charset=US-ASCII
organization: University of Illinois at Urbana
mime-version: 1.0
reply-to: grassu-list at max.cecer.army.mil
newsgroups: info.grass.user
originator: daemon at ux1.cso.uiuc.edu
Agustin, I found that your problem can be caused by *duplicate* lines
underneath the ones you see on the screen. To check this, use v.digit
to break some of the lines and remove a small bit of each line. Then
refresh the display and see if, mysteriously, the gap has been 'filled'.
Hope this helps,
Martijn van Leusen
> I keep on with problems with this coastlines vector.
> Mysteriously, there are closed polygons made up of
> edges that are open area lines. Hence, I cannot
> label the polygons as areas and get wrong results from
> v.cutter.
> What can I do to convert these open area lines into
> closed area lines? I repeat that the polygon is closed,
> all nodes are 2-lines nodes.
> Thanks!
> Agus
> Dr. Agustin Lobo
> Instituto de Ciencias de la Tierra (CSIC)
> Marti Franques s/n
> 08028 Barcelona (Spain)
> tel. 34 3 330 2716
> fax. 34 3 411 0012
> alobo at ija.csic.es
> alobo at eno.princeton.edu
