r.patch - found answer
    Casey Claiborne
    mskc at io.com
    Tue Mar 12 07:00:00 EST 1996
I figured out how to solve the problem.
I first used r.reclass to add another category to the list of categories
for the raster file. I then used r.support to actually update the
categories (move the data associated with cat 1 to cat 2).
Thanks
=================== PROBLEM BELOW ========================
hello,
        I have two raster files that I am trying to patch together -
one has the following:
0
1 lakes
The second one has the following
0
1 city
For the lakes I define (R=0,G=0,B=255). For the city, I define
(R=128,G=128,B=128). When combining the two, the color of the
lake is the same as the color of the city. I suspect it is
because both raster files have "Category 1" defined. If this is
the problem, how can one redefine the category of the lake? For
example, make the file
0
1
2 lake
and assign a value of (R=0,G=0,B=255) to the lake? Any help or
hints appreciated -
TIA
