r.contour
Brian Culpepper brian at cast.uark.edu
Thu May 2 08:00:00 EDT 1996
Teresa,
        Check to see if your resolution is the same as it was when
"it ran great".  It sounds as if your resolution may be different, so
compare the region of a good isopleth map to a bad isopleth map.
good luck,
        brian
On Thu, 2 May 1996, Teresa Salyer wrote:
> I'm trying to make a isopleth of some rainfall.  The r.contour program used
> to work great and take its time running reading all my raster map, but now
> it seems to just
> skim over it real fast creating contour lines with jagged edges.  The ones I
> did before are all smooth and seem to draw on the screen when displayed, the
> new ones just appear on the screen in one stroke and even catch the edge of
> the raster map as a contour.  What am I doing wrong???
> Thanks for all your help.   Teresa Salyer <salyer at tiaer.tarleton.edu>
R. Brian Culpepper                                Research Specialist
Center for Advanced Spatial Technologies           (fax) 501 575-5218
Rm. 12 Ozark Hall                                        501 575-6159
University of Arkansas                            brian at cast.uark.edu
Fayetteville, AR 72701               Home Page:  http://cast.uark.edu
