Accessing the Spearfish Dataset
Malcolm Williamson
malcolm at cast.uark.edu
Thu May 2 08:00:00 EDT 1996
On Wed, 1 May 1996, Jerry W. Cox wrote:
> Hello,
> I am a very new user of Grass and have ran into a problem accessing
> the Spearfish Database. At GRASS startup, I enter the location of spearfish
> and mapset of PERMANENT, and receive an error message saying that I do not
> have permission to access the data. I recently read the solution on the
> newsgroup, but did not think to save it. My thank you to those who respond
> directly to jerry at snowcrest.net.
> Have a nice day.
> Jerry W. Cox
Jerry,
The problem is that you are not the owner of PERMANENT. Instead, create a
mapset using your login as a name (that's the default, though you can
name it anything). Access (read only) to the PERMANENT mapset is through
the command "g.mapsets". Any map layers that are created or modified must
be in _your_ mapset. This is the normal protocol for using GRASS.
If you have anymore questions, feel free to e-mail me. Regards,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
