GRASS4.1.5 on Solaris 2.5 and ps.map
Iwao NODA
noda12 at ffpri-kys.affrc.go.jp
Fri Oct 25 08:00:00 EDT 1996
Dear Justin , Malcolm and grassusers:
I maybe could solve the problem concerning "installing GRASS4.1.5 onto
Solaris2.5".
Including problem of my mailed subject:"ps.map on Solaris 2.5". The ps.map
command works normally on Solaris2.5.
I happend to solve my above problem ,but I struggled by that time.
1. copying GRASS4.1.5 into Solaris2.5 on SUN sparc20 which I compiled on
SUN OS 4.1.3(Solaris1.1) ,SUN sparcIPX.
2.editting some file to match the directory-path environment( $GISBASE and
monitorcap ) to the SUN sparc20.
These are /usr/local.bin/grass4.1 and $GISBASE/etc/monitorcap.
3. generating $GISBASE/dev/fifo0a,fifo0b, ....
As I could not copy these fifo files, I used the files which I
beforehand generated with compiling procedure on the SUN sparc20.
GRASS4.1.5 binary for Solaris1.1 may work on Solaris2.5.
I sincerely appreciate your helpful suggestions, Justin , Malcolm and
grassusers.
At 11:07 AM 96.10.22 +0000, Justin Hickey wrote:
>On Oct 22, 9:52am, Iwao NODA wrote:
>> And , may I ask you ? I had many warnings as below when I compiled
>> GRASS4.1.5 with gcc on Solaris2.5.( however the installation was done) Is
>> that ok ? I worry that grass-commands might generate wrong results.
>> Thank you for your kindness.
>Iwao:
>I know most people ignore warnings from compilers and it is true that some of
>the warnings can be ignored. However, it has been my experience that warnings
>concerning pointers, especially incompatible pointer warnings, require at leas
t
>an investigation to see what the problem is.
Iwao Noda
Research Scientist
Forest Management and Economics Laboratory
Kyushu Research Center
Forestry & Forest Products Research Institute
Kurokami 4-11-16, Kumamoto 860, JAPAN
Fax: JAPAN(096)344-5054
Internet : noda12 at ffpri-kys.affrc.go.jp
