GRASS drivers for HP 755 Designjet Plotter
    Schmidt
    avenues at sonnet.com
    Sun Oct 20 08:00:00 EDT 1996
At 01:12 PM 10/18/96 -0500, you wrote:
>Hello--
>   Does anyone know where I can obtain GRASS plotter drivers for the HP
>755CM plotter?
>Thanks in advance.
>___________________________________________________________________________
 _____
>Mary F. Chang                                            Phone: (612)
>290-5615
>Computer Specialist                                        Fax: (612)
>290-5256
>St. Paul District Corps of Engineers
>mfc at ncs.usace.army.mil
>190 Fifth Street East                                           __  __
>__ __
>St. Paul, MN 55101-1638                                     / / /_  /_/
>/  /_
>                                                           /_/ __/ / /
>/_ /_
I've been using Alladin Ghostscript to convert the output from ps.map to rtl
format compatible with the Designjet 650C. I assume the same technique will
work with the 755CM. The web page for Ghostscript can be found at
www.cs.wisc.edu/~ghost/index.html.  Source code for Unix machines and
compiled code for DOS and Windows is available at the site. If you are
compiling for a Unix machine, make sure the driver dnj650c is included.
Jim Schmidt
