grass & solaris2.5
Angus Carr
apcarr at FLASH.LakeheadU.CA
Fri Apr 11 11:06:48 EDT 1997
I had this same problem, on Solaris 2.5.1, using the binary distribution.
My solution was to copy d.mon over from the SunOS binaries that I have
running on another box. It now works.
Make sure that the binary compatibility package is installed.
Angus Carr.
Masters of Forestry student
On Fri, 11 Apr 1997 zucco at dister.unige.it wrote:
> Hi grassusers,
> I've installed a solaris version on my sunsparc4 (grass4.1u5sol2.5 from
> moon /outgoing).
> When I digit the well knows d.command,
> GRASS-GRID>d.mon start=x0
> grass responds:
> Usage:
> d.mon
> (This command must be run interactively)
> GRASS-GRID>
> An if I follow the interactivity choosing the monitor listing option the
> response is the same!
> thanks for your help
> marino
> Flavio Poggi
> Dipartimento di Scienze della Terra
> Università di Genova
> Corso Europa, 26
> 16132 GENOVA (Italy)
> Tel.: +39 10 3538039
> Fax : +39 10 352169
> E-Mail: poggi at dister.unige.it
> HI MATES!!!!!
