problem compiling GRASS4.1
    Tian Qing
    tqing at ics.trieste.it
    Thu Apr 24 13:30:53 EDT 1997
Hello,
I met with the following problem when I compile GRASS4.1.
Please help me.
Many thanks.
Tian Qing
ICS,UNIDO
Trieste,Italy
e-mail: tqing at ics.trieste.it
Compiling error
GISBASE=/export/home/grass4.1/sun4
SRC=/export/home/grass4.1/src
CMD=/export/home/grass4.1/src/CMD
HEADER=SUN4
ARCH=sun4
GISGEN                              Thu Apr 24 19:02:36 MET DST 1997
 GISBASE = /export/home/grass4.1/sun4
 SRC     = /export/home/grass4.1/src
 CMD     = /export/home/grass4.1/src/CMD
 HEADER  = SUN4
 ARCH    = sun4
first step: src/libes/gis
GISGEN: src/libes/gis - Thu Apr 24 19:02:41 MET DST 1997
/export/home/grass4.1/src/libes/gis
  make -f OBJ.sun4/make.rules
rm -f OBJ.sun4/intr_char.o
gcc -O -DGETHOSTNAME_OK -I/export/home/grass4.1/src/include  -c intr_char.c
intr_char.c: In function `G_intr_char':
intr_char.c:17: storage size of `buf' isn't known
intr_char.c:19: `TIOCGETC' undeclared (first use this function)
intr_char.c:19: (Each undeclared identifier is reported only once
intr_char.c:19: for each function it appears in.)
make: *** [OBJ.sun4/intr_char.o] Error 1
GISGEN failure at STEP: src/libes/gis
Header file
CC                  = gcc
ARCH                = sun4
UNIX_BIN            = /usr/local/bin
DEFAULT_DATABASE    = /export/home/grass.data
DEFAULT_LOCATION    =
COMPILE_FLAGS       = -O
LDFLAGS             = -s
XCFLAGS             = -D_NO_PROTO
XLDFLAGS            =
XINCPATH            = -I/usr/openwin/include
XMINCPATH           =
XLIBPATH            = -L/usr/openwin/lib
XTLIBPATH           = -L/usr/lib
XMLIBPATH           = -L/usr/lib
XLIB                = -lX11
XTLIB               = -lXt
XMLIB               = -lXm
XEXTRALIBS          =
TERMLIB             = -ltermlib
CURSES              = -lcurses $(TERMLIB)
MATHLIB             = -lm
#                   LIBRULE = ar ruv $@ $?
#                   LIBRULE = ar ruv $@ $?; ranlib $@
#                   LIBRULE = ar ruv $@ $?; ar ts $@
#                   LIBRULE = ar rc $@ `lorder $(OBJ) | tsort`
USE_TERMIO          =
USE_MTIO            = -DUSE_MTIO
USE_FTIME           = -DUSE_FTIME
DIGITFLAGS          = -DUSE_SETREUID -DUSE_SETPRIORITY
VECTLIBFLAGS        =
GETHOSTNAME         = -DGETHOSTNAME_OK
configurations
SUN sparc 4
Solaris 2.5.1
gcc 2.7.2
make 3.74 (from FSF tools)
