aerial photo mosaic
Malcolm Williamson malcolm at cast.uark.edu
Fri Aug 15 09:54:41 EDT 1997
On Fri, 15 Aug 1997, Simon Cox wrote:
> Joe - r.patch messes with the color table in an
> attempt to maintain the appearance of the output.
> It treats the raster's as category maps, rather than
> continuous fields, so pixels with similar values do
> *not* get assigned similar colors.
> However, since the GRASS display colour-space is
> restricted to 216 colours, this usually fails for
> rasters with a large number of categories, such as images.
> Images are a particular problem, of course, since adjacent
> scenes frequently have different average levels, so features
> which any intelligent observer would interpret as continuous
> across the join will be really messed up.  Mosaicing
> remote-sending images successfully is a long-standing
> problem.  If you intend to do quantitative analysis you
> more-or-less have to do it one frame at a time.
> If you just want somthing that looks OK, than try manipulating
> the color look-up-table, either manually by editing
> gisdbase/location_name/mapset/cell/colr/map
> or by using r.colors
> (NB d.colors only changes the display so
> does not persist between sessions).
Let me expand on the above statement - d.colors _does_ permanently affect
your colortable _if_ you use the "save color table" (the "c" key) option.
I've been using it for years to edit my color table.
	-Malcolm Williamson
> __________________________________________________
> Dr Simon Cox - Australian Geodynamics Cooperative Research Centre
> CSIRO Exploration & Mining, PO Box 437, Nedlands, WA 6009 Australia
> T:  +61 8 9389 8421   F:  +61 8 9389 1906   Simon.Cox at dem.csiro.au
> http://www.ned.dem.csiro.au/SimonCox
