aerial photo mosaic
Simon Cox
simon at ned.dem.csiro.au
Fri Aug 15 12:56:02 EDT 1997
Joe - r.patch messes with the color table in an
attempt to maintain the appearance of the output.
It treats the raster's as category maps, rather than
continuous fields, so pixels with similar values do
*not* get assigned similar colors.
However, since the GRASS display colour-space is
restricted to 216 colours, this usually fails for
rasters with a large number of categories, such as images.
Images are a particular problem, of course, since adjacent
scenes frequently have different average levels, so features
which any intelligent observer would interpret as continuous
across the join will be really messed up. Mosaicing
remote-sending images successfully is a long-standing
problem. If you intend to do quantitative analysis you
more-or-less have to do it one frame at a time.
If you just want somthing that looks OK, than try manipulating
the color look-up-table, either manually by editing
gisdbase/location_name/mapset/cell/colr/map
or by using r.colors
(NB d.colors only changes the display so
does not persist between sessions).
__________________________________________________
Dr Simon Cox - Australian Geodynamics Cooperative Research Centre
CSIRO Exploration & Mining, PO Box 437, Nedlands, WA 6009 Australia
T: +61 8 9389 8421 F: +61 8 9389 1906 Simon.Cox at dem.csiro.au
http://www.ned.dem.csiro.au/SimonCox
