Floating point exception
Adalberto da Silva
adalbert at iag.usp.br
Thu Feb 6 09:41:17 EST 1997
Hello,
I'm trying to run s.surf.tps under Linux. I'm using Andreas Holz's
compilation.
When I run s.surf.tps and fill in with requested information (in this
case a site file with 150 thousand records extracted from a digitized
topographic map and the default parameters) I get the message:
>Floating point exception (core dumped)
Using s.surf.idw it seems to work but as fast as a snail (I aborted
operation when it had calculated about 50 ou of 6,000 lines! And my
Linux box is a Pentium 133 with 64 Megs...
I read some messages concerning the same issue apparently under Solaris
but I don't know what can apply to my problem.
Thanks,
Adalberto da Silva
Instituto Astronomico e Geofisico - USP
Sao Paulo - Brazil
