postscript output
Malcolm Williamson malcolm at cast.uark.edu
Mon Feb 10 16:12:17 EST 1997
Hi, David
I assume that your problem is with vector data. What update of GRASS are
you using? There was a fix to ps.map that should solve your problem; I'm
not sure if it is separately available on the moon or not. If you are
running pre-Update 5, I suggest getting and installing the latest version
of GRASS.
	-Malcolm
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Mon, 10 Feb 1997, David L. Certain wrote:
> Dear GRASS Users,
> I recently posted a message asking for help with a problem I am having printing
> a postscript file created with ps.map.  Thanks to those of you who responded.
> Progresss is being made.  I now know a little more about my problem and would
> like you to consider the following situation:  When printing my .ps file using
> the entire region of my study, my output is jumbled and mostly unrecognizable
> (e.g. polygons are not closed and are out of place, lines are disjointed,
> etc.).  As I print from smaller and smaller regions of my study area (using
> d.zoom to specify a new region and re-running ps.map) the output gets closer
> and closer to a coordinated image.  Finally, when I reach a certain region size
> (scale?) everything comes out juuuuust right.  Why can't I get good output when
> printing from the whole region?  For those of you that missed my last message
> it may be important to know that I am using an x,y coordinate system.  Any
> suggestions would again be greatly appreciated.
> David L. Certain
> Graduate Research Assistant
> Oklahoma Biological Survey
> 111 Chesapeake St.
> Norman, OK  73019
> (405)325-7598/fax (405)325-7702
> dcertain at obsnsrv1.bio.uoknor.edu
