mapping wildlife
Malcolm Williamson
malcolm at cast.uark.edu
Wed Feb 19 10:35:40 EST 1997
It sounds to me like you are planning your analysis around a vector data
format. That being the case, GRASS is not the package to use (I believe
that Arc/INFO has most of those features that you want). If you do
decide to stay with GRASS, you will need to change your modelling
approach to reflect a raster data model. I recommend C. Dana Tomlin's
_Geographic_Information_Systems_and_Cartographic_Modeling_ (Prentice
Hall) for a good overview of raster analysis techniques, most of which
may be applied in GRASS. Good luck!
-Malcoml
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Tue, 18 Feb 1997, J Lambert wrote:
> Greetings!
> I began using GRASS in January to analyze data for a study of bird
> territories and am wondering if there is a GRASS program or a series of
> operations that will allow me to randomly subsample a cluster of digitized
> points and automatically draw minimum convex polygons around the
> subsampled clusters. The points represent locations of bird observations
> and I hope to draw minimum convex polygons to estimate territory
> characteristics (size, perimeter length, minimum axis, maximum axis).
> If you are not familiar with any such programs, please refer me to
> individuals or organizations that may be using GRASS to map wildlife.
> I would greatly appreciate any feedback on this topic, as the
> ability to accurately estimate territory parameters with GRASS is central
> to my master's project.
> Thank you,
> Dan Lambert
> jlambert at gpu.srv.ualberta.ca
