Grass linux 4.1
Angus Carr
apcarr at FLASH.LakeheadU.CA
Fri Feb 28 16:52:57 EST 1997
It sounds like you haven't got it linked properly. The file s.to.vect goes
in the $(GISBASE)/etc/bin/contrib/cmd direstory, then
ln $(GISBASE)/front.end $(GISBASE)/bin/s.to.cell
Try that. This is just the second part of the install procedure, after
compiling.
Good luck.
Angus.
On Thu, 27 Feb 1997 fncesbl at bu.edu wrote:
> Hi,
> I recently posted a message about s.to.vect for Linux version of Grass, but
> had no reply from anyone. Perhaps you can help me as a Linux expert.
> I am running Grass 4.1 on a Linux 1.1 version (fall 95). I have downloaded
> the s.to.vect file from /outgoing at the moon site and unpacked it in the
> Grass/bin dir.
> But could not make it work and got the "can't open bin file" message. Can
> you tel me if I installed it incorrectly or should I get another file
> specifically for Linux from somewhere else?
> Thank you very much,
> -Francisco Estrada Belli
> Boston University
> Department of Archaeology
> 675 Commonwealth Ave
> Boston Ma 02215
