ps.map
Malcolm Williamson
malcolm at cast.uark.edu
Thu Jan 9 17:45:02 EST 1997
On Thu, 9 Jan 1997, Chris Cochran wrote:
> I am operating grass4.1 on SPARC system 600 SUNOS2.5. When using ps.map,
> I'll get a segmentation fault and core dump. This occurs both in the
> interactive mode and as a script. The ps.select command appears to be
> working ok. All other grass commands appear to work ok as well.
> This problem cropped up after our system was upgraded to OS2.5. We need
> a direct responce for this problem if at all possible. Thanks!
Hi, Chris
Did you re-compile GRASS when you upgraded to 2.5? If not, what release
of GRASS are you running? We are currently running 4.1.5 code, compiled
under Solaris2.3, on our Solaris2.5 systems, and have had no problems
with ps.map. I can ftp you binaries if needed.
Regards,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
