general importing info
Michael Hanratty
hanra001 at gold.tc.umn.edu
Wed Jul 2 10:23:37 EDT 1997
In message <3.0.1.32.19970701164847.00920a50 at email.psu.edu> writes:
> I have tried a number of methods to import some USGS data (dem and dlg)
> without success.
Here's what I've come up with for these two types of data:
Steps for importing USGS DLG files
1. Download from EROS Data Center (keep .gz suffix)
2. Unzip file using gzip -d fname
3. Divide into 80 character lines: fold fname > newfname
4. Import into GRASS: v.import
Options:
1
newfname
y UTM projection (sometimes not asked)
n Lines, not Areas
n Don't do multiple attribute (runs out of memory)
n Don't snap
To convert USGS dem files to GRASS format:
1. convert ascii file to binary:
m.dmaUSGSread top=1 bottom=1201 left=1 right=1201 output=binfname
logfile=logfname < demfname
2. Rotate binary file 90 degrees, creating dem in lat-long format
m.rot90 [-q] input=binfname output=llfname rows=1201 cols=1201
bpc=2
3. Convert from lat-long to UTM projection and put in GRASS database
r.in.ll [-s] input=llfname output=rastfname bpc=2
corner=corner,lat,lon dimension=1201,1201
res=3,3 spheroid=wgs72
The latitude and longitude of the sw corner is the first pair of
the 6-digit values in the header of the original dem file. These six
digit values are arc-seconds. Divide by 3600 to get degrees. Enter
these values in the corner= input value for r.in.ll.
Hope this helps.
Michael Hanratty Phone: (612) 627-4590
St. Anthony Falls Laboratory Fax: (612) 627-4609
Dept. of Civil Engineering
University of Minnesota
Mississippi River @ 3rd Ave. SE
Minneapolis, MN 55414
