Floating point exception
Jaro Hofierka
hofierka at netlab.sk
Fri Jul 11 02:29:53 EDT 1997
At 11:41 6.2.1997 -0300, you wrote:
> I'm trying to run s.surf.tps under Linux. I'm using Andreas Holz's
>compilation.
> When I run s.surf.tps and fill in with requested information (in this
>case a site file with 150 thousand records extracted from a digitized
>topographic map and the default parameters) I get the message:
> >Floating point exception (core dumped)
Hello GRASS users,
I fixed this problem for s.surf.tps under Linux. Sometimes the same error
appears with the message that only 3 points are within a given region.
The bug was in user1.c in missed declaration of atof() function.
The executable of s.surf.tps is available under request.
With regards,
Jaro
Jaro Hofierka
Mestsky urad
Dept. of MIS
085 01 Bardejov
Slovakia
e-mail: hofierka at netlab.sk
