r.in.tiff
William L. Baker
BakerWL at UWYO.EDU
Thu Jul 31 13:54:48 EDT 1997
After you bring in the file with r.in.tiff, then use
g.region to set the region equal to the file. If
the file is TEST, then g.region rast=test. Then
erase the screen (d.erase), and redisplay using
d.rast.
Bill Baker
To: grassu-list
Subject: r.in.tiff
Date: Thursday, July 31, 1997 5:20PM
I am trying to create a mosaic of aerial photos. (Thanks to the people who
responed to my previous request for help). I went through a test process
with
two photos, and all work well.
I then went back to do the other 28 photos but am running into problems with
r.in.tiff. This is what I did for the test.
I converted the jpeg file to tif using XV. The setting were best 24 -> 8,
full
colour, normal size, and no compression. I then run r.in.tiff ( down loaded
from the moon - r.in.tiff.sun). d.rast displayed the photos
I then converted all the jpeg files , but when I import them with r.in.tiff
I
get a black screen. There are no errors reported.
This is the output from r.in.tiff
Reading /export/home/users/joe/gis/data/wheat/airphoto/34525108.tif...TIFF
Directory at offset 0x163698
Image Width: 1240 Image Length: 1174
Resolution: 1200, 1200 pixels/inch
Bits/Sample: 8
Compression Scheme: none
Photometric Interpretation: palette color (RGB from colormap)
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 1
Rows/Strip: 1174
Planar Configuration: single image plane
Color Map: (present)
1 Strips:
0: [ 8, 1455760]
1240x1174x8 image
8 bits/sample, 1 samples/pixel
256 colormapped
Creating SUPPORT Files for 34525108
done.
Can anybody ofter any help?
thanks
joe
