r.in.tiff
    Malcolm Williamson
    malcolm at cast.uark.edu
    Thu Jul 31 09:24:08 EDT 1997
Hi, Joe
You've probably already done this, but I always start out by checking the
basics:
1. Is your region set to the new raster map? (g.region rast=mapname;
d.erase)
2. Do you have a MASK on? :)
If these criteria are ok, _and_ you really have data in your cell
directory, then you might run r.stats or r.report to assess the range of
values in the file. Good luck,
	-Malcolm Williamson
On Thu, 31 Jul 1997, Joe Leone wrote:
> Hi,
> I am trying to create a mosaic of aerial photos. (Thanks to the people who
> responed to my previous request for help). I went through a test process with
> two photos, and all work well.
> I then went back to do the other 28 photos but am running into problems with
> r.in.tiff.  This is what I did for the test.
> I converted the jpeg file to tif using XV. The setting were best 24 -> 8, full
> colour, normal size, and no compression.  I then run r.in.tiff ( down loaded
> from the moon -  r.in.tiff.sun). d.rast displayed the photos
> I then converted all the jpeg files , but when I import them with r.in.tiff I
> get a black screen.  There are no errors reported.
> This is the output from r.in.tiff
> Reading /export/home/users/joe/gis/data/wheat/airphoto/34525108.tif...TIFF
> Directory at offset 0x163698
>   Image Width: 1240 Image Length: 1174
>   Resolution: 1200, 1200 pixels/inch
>   Bits/Sample: 8
>   Compression Scheme: none
>   Photometric Interpretation: palette color (RGB from colormap)
>   Orientation: row 0 top, col 0 lhs
>   Samples/Pixel: 1
>   Rows/Strip: 1174
>   Planar Configuration: single image plane
>   Color Map: (present)
>   1 Strips:
>       0: [       8,  1455760]
> 1240x1174x8 image
>  8 bits/sample, 1 samples/pixel
>  256 colormapped
>  Creating SUPPORT Files for 34525108
> done.
> Can anybody ofter any help?
> thanks
> joe
