d.mon problem
Thomas Foster htf1 at psu.edu
Wed Jun 11 09:00:24 EDT 1997
Thanks for your response.   I'm afraid that it didn't work though.    I
changed the permissions on the /usr/grass/locks directory and got the same
error (see below).    Does it matter that there is no
/usr/grass/locks/foster/mon.* files.  there isn't even  a
/usr/grass/locks/foster in the /usr/grass/locks directory only a
/usr/grass/locks/topquark file... ?
>Thomas,
>check that permissions for /usr/grass/locks and any subdirectories is 666:
>	chmod -R 666 /usr/grass/locks
>Should do the trick. Good luck,
>	-Malcolm Williamson
>On Tue, 10 Jun 1997, Thomas Foster wrote:
>> I have recently installed Grass 4.15 running on Linux and I was trying to
>> display a monitor with d.mon.   At first I got an error saying to change the
>> permissions in the /usr/grass/dev/fifo.* files.   I did, then I got the
>> following error:
>> Graphics driver [x1] started
>> Error - Could not complete locking process for monitor <x1>.
>> Lock file is /usr/grass/locks/foster/mon.49158
>> Problem selecting x1.  will try once more
>> and then a monitor screen pops up but I can't do anything with it and d.mon
>> says that there are no monitors running.
>> What am I doing wrong.   I am new to Grass.   I read the manual on d.mon but
>> it didn't tell me anything about Lock files.   Any help would be
>> appreciated.  Thanks
Thomas Foster                            email: htf1 at psu.edu
Pennsylvania State University       voice: 814-865-1231
Department of Anthropology        fax:  814-863-1474
409 Carpenter Bldg.
University Park, PA 16802
