d.mon problem
grass at genie.saff.utah.edu grass at genie.saff.utah.edu
Fri Jun 13 10:46:06 EDT 1997
I'm reading this late so I don't know if its answered.
First, I had to limit my colors to 256 because I don't have the Motif
support yet. Try that, I was getting the same errors.
Jason Carey
Snow Hydrology
University of Utah
On Wed, 11 Jun 1997, Thomas Foster wrote:
> Thanks for your response.   I'm afraid that it didn't work though.    I
> changed the permissions on the /usr/grass/locks directory and got the same
> error (see below).    Does it matter that there is no
> /usr/grass/locks/foster/mon.* files.  there isn't even  a
> /usr/grass/locks/foster in the /usr/grass/locks directory only a
> /usr/grass/locks/topquark file... ?
> >Thomas,
> >check that permissions for /usr/grass/locks and any subdirectories is 666:
> >	chmod -R 666 /usr/grass/locks
> >Should do the trick. Good luck,
> >	-Malcolm Williamson
> >On Tue, 10 Jun 1997, Thomas Foster wrote:
> >> I have recently installed Grass 4.15 running on Linux and I was trying to
> >> display a monitor with d.mon.   At first I got an error saying to change the
> >> permissions in the /usr/grass/dev/fifo.* files.   I did, then I got the
> >> following error:
> >> Graphics driver [x1] started
> >> Error - Could not complete locking process for monitor <x1>.
> >> Lock file is /usr/grass/locks/foster/mon.49158
> >> Problem selecting x1.  will try once more
> >> and then a monitor screen pops up but I can't do anything with it and d.mon
> >> says that there are no monitors running.
> >> What am I doing wrong.   I am new to Grass.   I read the manual on d.mon but
> >> it didn't tell me anything about Lock files.   Any help would be
> >> appreciated.  Thanks
> Thomas Foster                            email: htf1 at psu.edu
> Pennsylvania State University       voice: 814-865-1231
> Department of Anthropology        fax:  814-863-1474
> 409 Carpenter Bldg.
> University Park, PA 16802
