s.surf.tps on Linux
Philip Verhagen
philip at raap2.ivambv.uva.nl
Fri Mar 14 05:31:22 EST 1997
> So I tried s.surf.tps and I got the message:
> warning: there are pionts outside of region - will ignore
> warning: strip exists with insufficient data
> warning: there are points outside specified region - ignored n (nearly all)
> points
> error: zero points in the given region
> - Input data format: 4434015 5628645 #44000
> - there are any #0 values
> - the region is set to default
Two guesses:
1) The input data should be separated with | (vertical bars)
2) Set your region to the extent of the site list with g.region; default
will probably not the right region (check this with g.region -p)
It is also worth considering creating a MASK that covers the area where
you have points available plus a reasonable buffer distance.
Hope this helps,
Philip Verhagen
R A A P
Plantage Muidergracht 14
1018 TV Amsterdam
The Netherlands
tel: +31 (20) 421 62 00
fax: +31 (20) 421 42 90
http://raap2.ivambv.uva.nl/home_eng.html
Philip
