Debugging Grasslinks
Simon Cox simon at ned.dem.csiro.au
Tue Mar 25 12:40:58 EST 1997
User of Grass wrote:
> I am trying to install Grasslinks2.0 ... but I keep coming
> up with an error message which is also redirected
> to the e-mail address. The message that I get is
> "GIS ERROR: region <> not found"
> Can you please give me some suggestions as to how
> I can get over this problem and get Grasslinks
> working.
Venkatesh
I'm afraid that I do not offer either support or degbugging
assistance for GRASSLinks.  However, the error message suggests
that either the part of the code which parses the "regions" file
in the "lists" directory is failing to pick up the set of
regions that you have available (check that file - eg for
blank lines, etc), or else the html form is not
returning a value to the cgi.  You'll have to use the usual
debugging tricks to track down the problem.
For my case, I've now moved on from GRASSLinks 2.0 and have
probably diverged irrevocably from the REGIS implementation.
The code has been completely re-written in perl, and I have
moved to a completely different metadatabase format - I do
not use files containing tables of the datasets any more,
but have developed a method to "publish" each dataset to the
application by creating a small metafile about it which is
placed in a known location.
I've also isolated the "GRASS" parts of the code deeper in the
structure.  My motivation for this is that I intend to further
develop the interface to use other modelling packages apart
from GRASS to work on different data types (eg 3D).
My latest version is converging on stability, so I expect to
make it available to other users soon, though this will continue
to be as-is - ie completely unsupported.
__________________________________________________
Dr Simon Cox - Australian Geodynamics Cooperative Research Centre
CSIRO Exploration & Mining, PO Box 437, Nedlands, WA 6009 Australia
T:  +61 9 389 8421   F:  +61 9 389 1906   simon at ned.dem.csiro.au
http://www.ned.dem.csiro.au/unrestricted/people/CoxSimon/
