Compile problem from a beginner.
Thomas Adams adams at ohrfc.noaa.gov
Wed Mar 26 07:50:45 EST 1997
Everything you want to compile under the standard GRASS distribution
that's contained in the lists/GRASS lists/local file must be
un-commented, i.e., delete the '#' symbol. The programs in the contrib/
garden/, etc. directories must be complied separately using the gmake4.1
command in each of those directories, but ONLY after successful
compilation of the the core GRASS programs.
Also, the programm v.support has a bug; so be sure to get the updated
code for build.vector.c. For details on this, look at the FAQs for
GRASS.
Cheers!
Tom Adams
Peizhong Wu wrote:
> Hi, When I try to run GISGEN.head,
> There is following error message:
> first step: #man
> GISGEN failure: #man - not found in lists/GRASS lists/local
> Would some people tell me why?
> Thanks very much
> Peizhong Wu
> University of Michigan
> Ann Arbor, MI 48105
Tom Adams                              adams at ohrfc.noaa.gov
Development & Operations Hydrologist   NWS-Ohio River Forecast Center
1901 S. State Route 134                Wilmington, OH 45177
(513) 383-0527 (VOICE)                 (513) 383-0033 (FAX)
