r.mapcalc
    Angus Carr
    apcarr at FLASH.LakeheadU.CA
    Tue Oct 21 05:10:26 EDT 1997
Try getting out of r.mapcalc and doing this as a shell script.
The syntax will vary.
This syntax works in BASH.
I am writing this off the top of my head, so you may need to play
with it a bit.
=========== start script ====================
bigmap=,
for map in $LOCATION/$MAPSET/a12*970124 ; do
map2=`echo ${map} | sed "s/$LOCATION\/$MAPSET/,/"`
bigmap=`echo ${bigmap}${map2}`
done
map3=`echo ${bigmap} | sed "s/,,/ /" `
r.mapcalc max970124=max(${map3})
=========== end script =====================
This script assembles a comma-separated list of maps in ${bigmap},
trims the leading pair of commas from the list, and then runs
r.mapcalc with them.
Good Luck!
Angus Carr.
> Hi GRASSers
> I 've got two questions (which I hope not to be to silly ;-) )
> -1-
> Is it possible to use r.mapcalc to calculate the minimum, maximum and /
> or the average of raster layers with using UNIX wild cards ("*" in my
> case) such as:
> r.mapcalc max970124=max(a12*970124*)
> to calculate a raster layer called max970124 of the maximum of all
> raster layers matching "a12*970124".
