XGRASS t/b/c
Justin Hickey
jhickey at impact1.hpcc.nectec.or.th
Wed Sep 17 06:05:52 EDT 1997
Hello Stephan
On Sep 16, 3:00pm, Stephan Eickschen wrote:
> Subject: XGRASS t/b/c
> thanks for your help!
No problem
> It seems, that you had all the same problems I am
> currently going through some times ago ;-) - and maybe the only one,
> you are the only "fountaine of knowledge"....
> So, as you might guesse, I have new problems and I would like to ask you
> for some help - now in direct way. I think, that I will send a summary
> of it all to the list, whenever I will have solved all problems.
Well I don't think a summary sent to the list will be much use as most of the
people on the list have grass compiled. I thought of doing that as well but for
the reason mentioned above, decided not to. However, I have recently finished
compiling the floating point version of grass and have found many programming
errors. I plan to contact the keepers of the ftp site to see if I can submit an
updated version of the code with all the changes to replace the current
floating point code.
> Now the libXbm.a is making trouble! As you might see from the output,
> which I attached as "GISGEN.txt", it was compiled and build without any
> (reported) error, but at linking there is something missing: the
> XAllocColor. As far as I am, it is defined in /usr/include/X11/Xlib.h.
> I added a #include <X11/Xlib.h> to _all_ create.c I found in
> $GIS/src/xgrass/.. because the error message complained about this file,
> but it did not help...
> Do you have again a simple clue as the two times before???
Yep, in the file $GIS/src/xgrass/display/Gmakefile there should be a line (line
10) which looks like
LIBS = $(BOGUS) $(XGDLIB) $(XGILIB) $(XXX) $(XPMLIB) $(BOGUS) $(YYY)
Change the line to be
LIBS = $(XGDLIB) $(XGILIB) $(XPMLIB) $(XXX) $(BOGUS) $(YYY)
That should now find XAllocColor
> Did you have more problems with xgrass of which I should be aware of or
> which might be avoided in a simple way? Did you summarize your
> "source-code-improvement"?
Yes I did but I have compiled the floating point version which I believe caused
some errors that you may not have encountered. Also, the "summary" of only the
xgrass stuff is over 1200 lines long because I included all warning and error
messages along with the fix I did for each. I'm picky when it comes to
compiling software and I like clean compiles (no warnings or errors). If you
really want the summary let me know and I'll put it on our ftp site.
Oh yes in the file $GIS/src/CMD/head/irix (I think it will be irix for you) the
XCFLAGS line should be as follows
XCFLAGS = -D_NO_PROTO -DXM_1_1_BC
The -DXM_1_1_BC flag is needed for some backward compatibility issues. Let me
know if you have any problems with this.
> P.S.: I hope, that I do not bother you too much...
Not at all. I'm more than happy to help.
Talk to you later.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
