Hurray :-)
    Stephan Eickschen
    eicksch at uni-muenster.de
    Wed Sep 17 10:50:03 EDT 1997
Hello Justin-
XGRASS is running! Thank you very much for your help, again!
What is - basicly - the difference between the "normal" grass and the
"floating point" version you have mentioned? I think, that I read this
words a while ago, but I can't remember anymore ...
Sincerly,
	Stephan
P.S.: Besides GRASS: Did you ever had problems with software on SGI-
	systems, which - previously - ran without problems on other
	machines, e.g. on IBM / Aix? I have some programs from collegues
	from NSIDC (http://www-nsidc.colorado.edu) for processing remote
	sensing data which I have succesfully installed on an IBM RS6000
	running AIX 4.1, but on our (new) SGI / IRIX 5.3 the compilation
	/ linking goes right, but the results are definatly wrong...
	It's all C code.
Stephan Eickschen                     Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
