Importing ArcInfo files
Malcolm Williamson malcolm at cast.uark.edu
Wed Aug 19 09:15:53 EDT 1998
Stephan,
The files that you are looking at are in the ArcINFO "export" format, as
indicated by the ".e00" extension. This is a proprietary format that
cannot be directly imported into GRASS. The only ArcINFO format that
GRASS can directly import is the ASCII "ungenerate" format. These days,
SDTS format is also a reasonable choice for moving files from ArcINFO to
GRASS (and vice versa).
The only way that I know of to get these files into GRASS is to use a
version of ArcINFO to translate them to one of the above mentioned
formats. Sorry!
	-Malcolm Williamson
 On Wed, 19 Aug 1998, Stephan Eickschen wrote:
> Hi all,
> I have downloaded some data from the Antarctic Digital Database
> (http://www.nerc-bas.ac.uk/public/magic/add_main.html). They are
> supposed to be ArcInfo files containing coastlines, surface featuers
> and so on. But I really do not know how to import them into GRASS. I
> attach the reult of
> head *.e00 >! ADD.ArcInfo.files
> If someone needs the complete file(s), please feel free to look at
> 	http://earth.uni-muenster.de/~eicksch/ftp/GRASS_DATA/
> There you will find all of them.
> Any suggestion will be highly appriciated,
> 	Stephan
> Stephan Eickschen                     Tel. : +49 (0)251 83-34704
> Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
> Institute for Geophysics
> Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
> Corrensstrasse 24
> 48149 Muenster
> Germany
