m.in.e00
    Markus Neteler
    neteler at geog.uni-hannover.de
    Thu Dec  3 13:29:04 EST 1998
> I compiled the m.in.e00 module on a SUN Sun0s 4.13.  It works fine on very very
> small e00 files, but when trying to import a 625,000 byte (which is still quite
> small), I get the following error message:
> ERROR: G_malloc:  out of memory.
> I have compile m.in.e00 in linux and it works just fine on the same e00 file, so
> I feel I have something wrong in my variable on the SUN system.
Hi Anthony,
you should check the /tmp and other directories, if there is *always*
enough space. G_malloc error sounds like a full harddisk... (maybe there is
an overflow only during .tmp-file creation).
Check it several times meanwhile the module is running. Otherwise Michel
might help :)
Markus Neteler
