TclTkGRASS 2.5 released
Markus Neteler
neteler at geog.uni-hannover.de
Mon Dec 7 06:09:45 EST 1998
Hi again,
TclTKGRASS 2.5 - the platform independent graphical user
interface for GRASS is released:
http://www.geog.uni-hannover.de/grass/main_tclgrass.html
(on the mirrors soon)
We all have to thank Jacques Bouchard for his big job on
the user interface!
The software is tested on SUN/SGI/Linux.
Important, when *updating*: You have to remove former
versions and the startscript link in
/usr/local/bin
So, what's new:
- bug fixes, several new modules integrated in menus
- improved structure
- new installation procedure (with "make")
the "tcltkgrass" directory can be put anywhere
- "tcltkgrass" must now be launched from the GRASS shell
(as the TCL/TK shell was not very pleasant to use);
GRASS and TCLTKGRASS can be used at the same time
- new "Config" menu
+ several monitors can be started / stopped with one action
+ global management of module windows
+ font selection
+ default driver geometry can be set
- the monitors geometry is saved / restored
(unfortunately, this is known to be bugged on SGI IRIX)
- the active monitor is now erased after region operations
Have fun
Jacques Bouchard & Markus Neteler
