grass421_on_linux:compilation errors.
Malcolm Williamson malcolm at cast.uark.edu
Wed Dec 16 09:55:29 EST 1998
Skip,
I obviously can't answer for Dr. Lobo, but I can for myself and probably
many other long-time GRASS users. One of the great strengths of GRASS has
been the ability to utilize contributed programs, which are typically
distributed solely as source code. Although Markus et al have done a
fantastic job at gathering and compiling the latest contributed programs,
it is nice not to have to rely upon someone else's priorities and
schedule. Also, you don't have to be a C programming wizard to make minor
modifications and customizations to GRASS programs. In either case, it is
a fine thing to have the ability to compile. My $.02.
	-Malcolm
On Wed, 16 Dec 1998, Skip Haak wrote:
> Dr. Lobo,
> Is there some reason you're not using the binaries available for GRASS? I
> also use RH 5.1. I downloaded the binaries and was up and running in a
> matter of minutes.
> Skip Haak
> >Hi!
> >I've compiled most of the programs on a
> >Linux (RedHat 5.1) box, but got some problems with
> >1. g77 (see below)
> >Should not gcc take care of F77 ?
> >It seems that I do not have a g77 compiler, is it not
> >standard with the Linux distribution?
> >2. and then another one with run.setup
> >/usr/local/grass42/src421/src.related/rim
> >  mkdir OBJ.linux
> >  make -f OBJ.linux/make.rules
> >run.setup
> >make: run.setup: Command not found
> >make: *** [rim] Error 127
> >GISGEN failure at STEP: src.related/rim
> >Any help?
> >Thanks
> >Dr. Agustin Lobo
> >Instituto de Ciencias de la Tierra (CSIC)
> >Lluis Sole Sabaris s/n
> >08028 Barcelona SPAIN
> >tel 34 93409 5410
> >fax 34 93411 0012
> >alobo at ija.csic.es
> >http://pangea.ija.csic.es/alobo
> >/usr/local/grass42/src421/src.contrib/CERL/misc/m.eigensystem
> >  mkdir OBJ.linux
> >rm -f OBJ.linux/main.o
> >g77  -c main.f
> >make: g77: Command not found
> >make: *** [OBJ.linux/main.o] Error 127
> >GISGEN failure at STEP: src.contrib/CERL/misc/m.eigensystem
> >[root at localhost CMD]# pwd
> >/usr/local/grass42/src421/src/CMD
> >/usr/local/grass42/src421/src.garden/answers/src.answers/answers
> >  mkdir OBJ.linux
> >make[1]: Entering directory
> >`/usr/local/grass42/src421/src.garden/answers/src.answers/answers'
> >rm -f OBJ.linux/answers.o
> >g77  -c answers.f
> >make[1]: g77: Command not found
> >make[1]: *** [OBJ.linux/answers.o] Error 127
> >make[1]: Leaving directory
> >make: *** [all] Error 1
> >GISGEN failure at STEP: src.garden/answers/src.answers
> >/usr/local/grass42/src421/src.garden/answers/raster/r.direct/cmd
> >  mkdir OBJ.linux
> >`/usr/local/grass42/src421/src.garden/answers/raster/r.direct/cmd'
> >rm -f OBJ.linux/direct.o
> >gcc -O2 -m486 -DATT_386  -I/usr/local/grass42/src421/src/include
> >-DUSE_TERMIO -c direct.c
> >direct.c: In function `main':
> >direct.c:77: warning: passing arg 1 of `strcpy' from incompatible pointer
> >type
> >direct.c:78: warning: passing arg 1 of `strcpy' from incompatible pointer
> >type
> >mv direct.o OBJ.linux/direct.o
> >rm -f OBJ.linux/cell_open.o
> >-DUSE_TERMIO -c cell_open.c
> >mv cell_open.o OBJ.linux/cell_open.o
> >rm -f OBJ.linux/cell_open_new.o
> >-DUSE_TERMIO -c cell_open_new.c
> >mv cell_open_new.o OBJ.linux/cell_open_new.o
> >gcc -Wl,-s OBJ.linux/direct.o OBJ.linux/cell_open.o
> >/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a -lm -o
> >/usr/local/grass42/etc/bin/alpha/cmd/r.direct
> >/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(gets.o): In
> >function `G_gets':
> >gets.o(.text+0x60): the `gets' function is dangerous and should not be used.
> >rm -f OBJ.linux/direct_for.o
> >g77  -c direct_for.f
> >make[1]: *** [OBJ.linux/direct_for.o] Error 127
> >GISGEN failure at STEP: src.garden/answers/raster/r.direct
> >  mkdir OBJ.linux
> >run.setup
> >/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim/cmd
> >  mkdir OBJ.linux
> >make[2]: Entering directory
> >`/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim/cmd'
> >rm -f OBJ.linux/highlevel.o
> >-DUSE_TERMIO -c highlevel.c
> >mv highlevel.o OBJ.linux/highlevel.o
> >cc -Wl,-s -o /usr/local/grass42/etc/bin/main/cmd/s.db.rim
> >OBJ.linux/highlevel.o /usr/local/grass42/src421/src/libes/LIB.linux/libgis.a
> >/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(parser.o): In
> >function `interactive_option':
> >parser.o(.text+0x1331): the `gets' function is dangerous and should not
> >be used.
> >rm -f OBJ.linux/s.db.rim.o
> >g77  -c s.db.rim.f
> >make[2]: g77: Command not found
> >make[2]: *** [OBJ.linux/s.db.rim.o] Error 127
> >make[2]: Leaving directory
> >make[1]: *** [all] Error 1
> >`/usr/local/grass42/src421/src.garden/grass.rim/s.db.rim'
> >GISGEN failure at STEP: src.garden/grass.rim
