r.out.bil : bug fixed
Phisan Santitamnont fsvpss at eng.chula.ac.th
Thu Dec 17 23:44:43 EST 1998
Dear colleagues,
there some wrong tippo in r.out.bil, which is
needed to export raster from grass to ArcView.
Phisan Santitamnont, Dr.-Ing. Tel. +66 (2) 218 66 61
Survey Engineering Dept.      Fax. +66 (2) 218 66 53
Chulalongkorn Univ.    mailto:fsvpss at eng.chula.ac.th
Pathumwan Rd, Bangkok 10330
Homepage: http://www.sv.eng.chula.ac.th/Staff/Phisan
#!/bin/sh
# This script reads a GRASS cellhd file and creates a
# "world" file and "header" file for display in ArcView
# or ArcInfo as a "bil" file. T. D'Avello 12/18/97.
# (Color schemes in GRASS won't replicate in AV)
# USAGE: r.out.bil <raster_file>
if [ "${1}" = "" ]
    then
      echo "Enter GRASS raster FILENAME  "
       read FILENAME
	else
	 FILENAME=$1
fi
if [ "${FILENAME}" = "" ]
     then
       echo "ERROR: You MUST enter a filename.  -- Command aborted!"
	exit 4
fi
if [ ! -s $LOCATION/cellhd/${FILENAME} ]
   then
	echo "ERROR:  File not found"
	echo "ERROR:  Run this command in MAPSET containing data"
	exit 5
fi
cell=$LOCATION/cellhd
#  Get info from cellhd for bilw and hdr
res=`cut -c13- $cell/$FILENAME | sed -n '9p'`
col=`cut -c13- $cell/$FILENAME | sed -n '7p'`
row=`cut -c13- $cell/$FILENAME | sed -n '8p'`
nrt=`cut -c13- $cell/$FILENAME | sed -n '3p'`
wst=`cut -c13- $cell/$FILENAME | sed -n '6p'`
compress=`cut -c13 $cell/$FILENAME | sed -n '12p'`
# check for compression status and uncompress if needed
 if [ "$compress" -eq 1 ]
   then
     r.compress -u map=$FILENAME
      echo "Uncompressing GRASS file"
 fi
# Make directory "BIL" to store resulting files
if [ ! -d $LOCATION/BIL ]
     then
     mkdir $LOCATION/BIL
fi
# Write Header file
echo "nrows $row" >> $LOCATION/BIL/$FILENAME.hdr
echo "ncols $col" >> $LOCATION/BIL/$FILENAME.hdr
echo "nbands 1" >> $LOCATION/BIL/$FILENAME.hdr
echo "nbits 8" >> $LOCATION/BIL/$FILENAME.hdr
echo "layout bil" >> $LOCATION/BIL/$FILENAME.hdr
echo "skipbytes 0" >> $LOCATION/BIL/$FILENAME.hdr
echo "bandrowbytes $col" >> $LOCATION/BIL/$FILENAME.hdr
echo "totalrowbytes $col" >> $LOCATION/BIL/$FILENAME.hdr
# Variables for world file
echo "$wst	$nrt	$res" > 1.tmp
# Write World file
ulx=`cat 1.tmp | awk '{ printf("%f",$1-($3*0.5)) }'`
uly=`cat 1.tmp | awk '{ printf("%f",$2-($3*0.5)) }'`
echo "$res" >> $LOCATION/BIL/$FILENAME.bilw
echo "0.0" >> $LOCATION/BIL/$FILENAME.bilw
echo "-$res" >> $LOCATION/BIL/$FILENAME.bilw
echo "$ulx" >> $LOCATION/BIL/$FILENAME.bilw
echo "$uly" >> $LOCATION/BIL/$FILENAME.bilw
cp $LOCATION/cell/$FILENAME $LOCATION/BIL/$FILENAME.bil
rm 1.tmp
